#1 |
Extending a deck
I have a 17L x 10W wood deck. It is 12 feet above ground supported with three 4X6 posts. The joists are 2x10. There is no cantilevering (i.e the outside band sits on the 4X6 posts. Structurally, everything is solid with no rot. I want to extend the deck by 2 or 3 feet to make it 17 x 12 or 13. How can I extend this by using the existing structure, including joists and posts without adding new posts?
#2 | |
Extending a deckQuote:
Either add a new beam and posts (and then verify that the existing beam and piers can handle the additional load), replace joists with longer joists and new beams/piers/posts, IF the piers are sufficient for the new load you could remove the beam and replace with a dropped beam and new joists cantilevered over the beam.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| The Following User Says Thank You to robertcdf For This Useful Post: | woodworkbykirk (02-20-2013) |
#3 |
Extending a deck
Post a picture of what you have now!
#4 |
journeyman carpenter
Extending a deck
by code you cant cantilever a deck joist more than 2' past the beam unless its a engineered design
| Display Modes | |
| Extending deck & Pressure treated joist life | OR DIY guy | Building & Construction | 2 | 05-23-2012 09:59 PM |
| Pergola over existing deck | cpfullback | Building & Construction | 0 | 08-04-2011 12:36 PM |
| Deck Staining Nightmare | steven994 | Painting | 2 | 06-17-2010 08:21 AM |
| Building a new deck....and creative uses of granite scrap in outdoor living space | Rhizzlebop | Building & Construction | 9 | 05-15-2009 12:17 PM |
