Extending A Carport, And Enclosing New Section - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-06-2012, 04:15 PM   #1
extending a carport, and enclosing new section
what size do I need for roof support , and what spacing do i need to use? 16 ft. span, and an 80 pound show load.
duncan2highland is offline   Reply With Quote
Old 01-06-2012, 05:13 PM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 802
Welcome to DIY
What is a "show" load?
It helps to put your location in your profile.
There is not really enough information in your question. We don't know what type of car port you have now. I'm going to assume you mean "snow load".
In most areas, a car port requires permits....especially in areas where snow load is an issue. Hence, your first questions should be at the building office.
ddawg16 is online now   Reply With Quote
Old 01-06-2012, 08:49 PM   #3
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Generally here in CA. we require 12.5 cubits/league for support and a spacing of 10to 12th angstroms for the spacing.
An 80 lb. show load needs a show boat that will displace 200k metric tonnes.
I hope this helps.
Andy.
AndyGump is offline   Reply With Quote
Old 01-06-2012, 11:07 PM   #4
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
I hope this helps.
Andy.
What the heck are you talking about?
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-07-2012, 12:38 AM   #5
AndyGump's Avatar
Rewards Points: 660
It is all in the code book.
Very standard conventional stuff.
Andy.
Old 01-07-2012, 12:47 AM   #6
Disabled wood vet
titanoman's Avatar
Andy.
Easy for yuuuu....
Old 01-07-2012, 12:53 AM   #7
Rewards Points: 12,802
No pictures, no drawings, almost no info.
Even then without being on site anyone here would have to guess.
If you have these type questions it may be best to hire someone local to give you a hand that does this type work.
Old 01-07-2012, 01:00 AM   #8
AndyGump's Avatar
Rewards Points: 660
Ha, good zinger Joe...oh wait...
that was boring as heck...you are no fun Joe.
Andy.
Old 01-07-2012, 05:43 PM   #9
Rewards Points: 2,202
please give more info.
Are you stick building your own roof?
Is this for the rafters, ridge board, beam?
mae-ling is offline   Reply With Quote
Old 01-08-2012, 02:41 AM   #10
Retired carpenter
You say you are extending your carport, right? Is your current carport holding OK? If so, just copy what you got.
abracaboom is offline   Reply With Quote
enclosing garage, non-load bearing stucco wall - do I need to cut slab & dig footing? eric559 Building & Construction 3 07-07-2010 02:41 AM
enclosing a carport bobo125 Building & Construction 5 01-01-2009 06:30 PM
