Extend Sonotube For Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 08:14 PM   #1
Rewards Points: 93
Extend sonotube for deck
I took down my old deck and getting ready to rebuild. After making sure the pillars created with the sonotube are level, they arent. From the tallest one to the lowest, there is a 2 3/4" gap, 3/4", 1/4". To fix this i was going to use small peices of sonotube, clean the top of the pillar, and use cement primer then cement to raise the pillars. Is this a bad idea? What kind of cement can i use for this?
simonb is offline   Reply With Quote
Old 05-07-2011, 09:29 PM   #2
Rewards Points: 5,336
Cutting or grinding them level would be my solution.
Ron
Old 05-07-2011, 09:44 PM   #3
Rewards Points: 93
There is a retaining wall that holds part of the deck that cant be cut lower.
Old 05-07-2011, 10:16 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
why do you need to raise the pillar? Are you setting the joists directly on the pillars? If so, I doubt a layer as thin as what you are dealing with would have enough strength to last for very long.
and if so, why are you setting the joists directly on the pillars? How are you attaching them or are you not attaching them?
Old 05-07-2011, 10:21 PM   #5
Rewards Points: 93
The deck is not attached to the house. The pillars and retaining wall are used to seat 6x6 beams that will hold the joist.
Old 05-07-2011, 10:36 PM   #6
nap
You talking to me?
nap's Avatar
so, are you planning on just setting the beams on the pillars?
If you are, I doubt what you are attempting would last. There is not much strength in a 1/4 inch of concrete or even 3/4". Personally, I wouldn't trust the 2 3/4" addition to last.
Old 05-07-2011, 10:42 PM   #7
Rewards Points: 93
what about a quickset non shrink grout instead? If not what would you suggest then?
Old 05-08-2011, 06:22 AM   #8
Rewards Points: 93
Any one else have any ideas or suggestions?
Old 05-08-2011, 07:49 AM   #9
Old School
Willie T's Avatar
Yes, simply use deeper joists than original where the pilings are lower, and notch them to fit.
Willie T
Old 05-08-2011, 08:33 AM   #10
Rewards Points: 93
Well that could work but the joist are 2x8 and i already bought and got delivered all my lumber. I would rather start off with a level footing and build up from that.
Im thinking of using saddles and shimming them to the proper height. This way i start level. Also once i drill the hole for the saddle i would use a anchoring adhesive.
http://www.strongtie.com/products/co...nada/RCPS.html
Old 05-08-2011, 09:28 AM   #11
shimmed saddles or compressive non-shrink grout
The older I get the better I was
HELP Extend Gas Line mxingislife Plumbing 41 03-14-2013 09:08 AM
Sonotube size? MarcHRob Building & Construction 2 05-23-2010 10:15 PM
How do I extend my deck? yummy mummy Building & Construction 6 04-05-2010 05:14 PM
Extend outdoor electric? Is it possible? Skalek Electrical 11 06-30-2009 09:29 PM
Tiling on cardboard tube (sonotube) DeFex Tiling, ceramics, marble 7 05-20-2009 03:17 PM
