Exposure Brick In Wall Shelving - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-05-2012, 10:58 PM   #1
I'm renovating a basement and I'm take down a section of drywall and exposing the brick to create more space. I plan on building a built-in shelving space. My plan is to double up the stud frames with another set of studs to create a box. All the studs will be fixed to the mason with masonry nails. The studs then will be lined with plywood and a oak veneer. I will finish with wood trim. The top of the section will have light and the shelves will be glass.
My question is the brick work. The brick looks in good shape but it looks dirty and dusty. How do I clean the brick? Also is there a process to fill in some of the holes in the brick so it looks newer? What about the mortar between th brick? The mortar looks solid but there are some areas where its not flush with the brickwork and I would like to fill it in. Recommendations on products, websites and books are appreciated!
dzobrist is offline   Reply With Quote
Old 02-05-2012, 11:03 PM   #2
Rewards Points: 13,960
Google tuck pointing.
Any new morter is not going to match the old for many years.
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
brick wall window -- replacement review amakarevic Building & Construction 3 01-24-2012 01:48 PM
Question Re. Parging Over Brick Captain.Sassy Building & Construction 19 06-22-2010 08:50 AM
Question regarding adding a stud wall to a brick structure jcieutat Building & Construction 0 12-15-2009 07:41 PM
Insulating brick above & close to grade Peter Shepherd Building & Construction 1 09-16-2009 06:41 AM
