-   -   Exposed sill plate/gap at stairs... how to protect? (http://www.diychatroom.com/f19/exposed-sill-plate-gap-stairs-how-protect-157506/)
thinksincode 09-21-2012 10:44 AM
Happy Friday, all!
So a friend of mine recently helped me rebuild my deck stairs. Unfortunately I noticed a bit of a problem. The tread on the replacement stairs were a bit smaller than the old ones and now there's some wood from what I think is the sill plate exposed to the elements, along with a gap that surely will let water get trapped in there and cause rot.
What is the right way to seal/protect this to prevent damage?
Here's a picture:
https://lh4.googleusercontent.com/-S...915_175804.jpg
hammerlane 09-21-2012 11:01 AM
1 Attachment(s)
That looks like a rim joist. Can you post a photo a little further back?
thinksincode 09-21-2012 11:06 AM
Ah, I should've known I'd get the terminology wrong. :) I will get a wider angle photo for you this afternoon. Thanks!
allthumbsdiy 09-21-2012 11:46 AM
I am going to guess but that wood you see next to the step is an exterior plywood. Your rim band/joist and sill plate(s) would be on the other side of that plywood.
I think the correct way to protect your plywood, rim joist/band, and sill plate(s) would be to temporarily remove those steps, peel back siding, install a house wrap (i.e. Tyvek), then some type of self-sealing bituminous membrane (i.e. Ice Dam Shield), then re-install siding.
I would also leave a 2" gap between the siding and the steps as well.
Good luck
PS. Make sure the ice dam shield extends about 3" below the line where plywood meets your basement foundation to prevent water from kicking/wicking up
thinksincode 09-21-2012 03:22 PM
Here's a wider shot.
https://lh4.googleusercontent.com/-y...921_152801.jpg
kwikfishron 09-21-2012 04:46 PM
199 Attachment(s)
Have any more of that siding laying around?
joecaption 09-21-2012 06:38 PM
The stairs should have been built out away from the siding so there was room for the siding.
Gary in WA 09-21-2012 09:14 PM
It appears you lost the minimum tread depth required by code, otherwise it would fit; http://publicecodes.cyberregs.com/ic...?bu2=undefined
Your riser heights vary by way more than code maximum; http://publicecodes.cyberregs.com/ic...?bu2=undefined
The nosing is wrong also: http://publicecodes.cyberregs.com/ic...?bu2=undefined
I'd just rebuild them, use 4 stringers if required (maximum 16" or 12" - check with manufacturer), unless you have it, hard to measure my screen picture...
Gary
Pianolady 09-21-2012 10:07 PM
Could he remove the treads on that stair and use something like this as flashing over the exposed wood? Even comes in blue.
joecaption 09-21-2012 10:17 PM
Why pay $80 and only need 2' of the material?
Just rebuild them right and there's no wall exposted.
Pianolady 09-21-2012 10:22 PM
I believe you can buy it by the foot instead. Don't need 50'.
joecaption 09-21-2012 10:27 PM
Where would you find a place to buy any color but white by the ft.?
Pianolady 09-21-2012 10:28 PM
Any of these work?
This product comes in a wide variety of colors, not sure where you could buy it, but imagine you could contact them and find out.
joecaption 09-21-2012 10:37 PM
Still would not address all the other issues and the messed up J moulding that going to now let water in behind the water.
Pianolady 09-21-2012 10:47 PM
True. But it would be better than doing nothing if OP doesn't want to rebuild the steps. Even prime & paint would be better than doing nothing. I'm not claiming it would be the ideal solution. The j molding is messed up either way and needs to be adjusted or replaced.
