Exposed Painting Ceiling And Finishing Between Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-28-2013, 12:01 PM   #1
bryanp22's Avatar
Rewards Points: 288
Exposed painting ceiling and finishing between joists
Hi
Just wondering how people have finished the area between joists on an exposed ceiling. Do you just drywall into that space? I was just going to use XPS and paint it black initially but it needs a 15 minute fire barrier in front of it I guess.
bryanp22 is offline   Reply With Quote
Old 08-28-2013, 05:10 PM   #2
DIY staff
Rewards Points: 7,174
Could you tell us what you are planning to do?
If you are painting the underside of a floor structure---most times little is done except prime and paint---I've never heard of installing drywall between the floor joists---
Old 08-28-2013, 05:14 PM   #3
bryanp22's Avatar
Rewards Points: 288
I'm painting the ceiling of half my basement. The other side is laundry, utilities and storage. Partly I want to avoid overspray going to otherwise I basement that is not being finished but also want to give it a closed off look with exposed ceiling.
Old 08-28-2013, 05:36 PM   #4
DIY staff
I suggest you experiment---usually there is to much in the way of X-bracing--pipes--conduit and such to be able to add drywall to the bottom of the subfloor---
If you decide to try it---there is a plastic J-channel that is used to hide the cut edges when drywall butts against a finished surface--
Old 08-28-2013, 05:46 PM   #5
bryanp22's Avatar
Rewards Points: 288
Do you end up seeing the edge of the j channel? I was really hoping for a clean edge so is just latex caulk an alternative to j channel?
Old 08-28-2013, 07:39 PM   #6
DIY staff
Sure you will see the J-channel---but it's better than the ragged edge of paper the is left from cutting drywall.
Old 08-29-2013, 11:53 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Be sure you check with code in your area about exposed foams and the thermal barrier requirements.
They are more stringent than an ignition barrier.
Painting basement ceiling...drywall first or paint first? jdtox Painting 3 10-15-2012 09:33 PM
Basement Finishing, Where to start? Ceiling? swarren Remodeling 8 01-08-2012 06:27 PM
Garage ceiling joists and beam question Truth Building & Construction 8 01-05-2012 08:52 PM
Drop ceiling with Steel Floor Joists stanlemon Remodeling 5 11-16-2010 05:11 PM
finishing a drywall ceiling mmhendrie Building & Construction 12 03-17-2009 10:11 AM
