Old 05-05-2013, 05:27 PM   #1
Exposed Interior Brick Questions
In my kitchen I have taken the plaster off of the brick outside wall. I have repointed the brick and I am wanting to put some sort of finish on the brick. Oddly enough there is very little information on the Internet about interior brick and coating it. My preference is to clear coat it with polyurethane, however I have since read that doing so might cause a few problems, mainly creating a "condensate point" because it is an outside wall and a heated space. I am not sure that information is accurate or not.
My question is: What can I use to put a coating on the brick that is durable enough to withstand being cleaned (read kitchen grease etc) and still allow the natural brick to show? Painting is not an option because I have designed my kitchen to include this natural brick look.
Any suggestions?
FClef is offline   Reply With Quote
Old 05-05-2013, 06:00 PM   #2
Long-term, are you sure you would want to leave it exposed brick? If it was plastered over, chances are it will be a cheap common brick with no particular claim to appearance.
It might make the kitchen a bit dark and will be difficult to clean, even if coated.
tony.g is offline   Reply With Quote
Old 05-05-2013, 06:09 PM   #3
how about a brick sealer from a masonry supply house the "seal" brick but allow the brick to breath
be careful my advice only comes from general knowledge i know about the 4 rules it takes to plumb and they are
1 poop needs to flow down hill. 2 hot on left cold on right
3 i get a pay check on Mondays 4 do not chew finger nails at or after work.
jaydevries is online now   Reply With Quote
Old 05-05-2013, 10:08 PM   #4
I definitely want to keep the brick exposed because my entire kitchen has been designed to include this look. The brick is the same brick on the outside of the house so it looks great.
Old 05-05-2013, 10:10 PM   #5
I guess the question is if the sealer will be enough to protect the brick and allow it to be cleaned without destroying the sealer.
Exposed Foundation Concerns irish4032 Building & Construction 6 03-15-2013 10:54 PM
Safe to seal exposed cinder block wall in basement? cne24 Concrete, Stone & Masonry 4 09-20-2012 08:43 PM
Exposed WIRING ON BOTTOM OF JOISTS. pp2815 Electrical 12 05-01-2012 03:32 AM
Questions on tying 6x8 exposed header to top plate EDI Remodeling 4 06-03-2010 09:27 PM
How thick should my thinset be? yummy mummy Tiling, ceramics, marble 20 09-28-2009 01:36 PM
