Exposed Insulation...safe To Shower? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-10-2010, 11:00 PM   #1
Just call me Andrew
Rewards Points: 1,020
Exposed insulation...safe to shower?
I am in the middle of remodeling 2 bathrooms at once. Currently, the only shower is in the upstairs bathroom (Finished attic).
There is no sheetrock up, so the wall/ceiling insulation is exposed. Should steam be a concern? I have been showering with the door open and the window if weather allows. It will be a few more days before sheetrock is up. I've been taking quicker/cooler showers....is that necessary?
Andrew
secutanudu is online now   Reply With Quote
Old 05-11-2010, 10:22 PM   #2
Registered User
Rewards Points: 5,216
Plastic stapled up works. Keep the moisture away from the insulation/wood to grow mold when the temperature is right: http://www.fpl.fs.fed.us/documnts/pdf2000/tenwo00a.pdf
http://www.ag.ndsu.edu/pubs/yf/home/ae1202w.htm
Be safe, Gary
How To Install Rigid Foam Insulation on Concrete earthad1 Building & Construction 9 10-26-2010 10:49 AM
How to tile around a Pre fab shower base geoffthemonk Building & Construction 1 11-07-2009 10:10 AM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
Shower Pan Liner Problem Hottrod33 Plumbing 9 02-02-2009 02:02 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 09:16 AM
