Exposed Ceiling Joist - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-25-2011, 12:33 PM   #1
baj
Exposed ceiling joist
I have a home built in 1928.Ceilings are plaster and lathe.I want to remove the existing ceiling and leave the joists exposed.What would be the best material to put on top of joists as the ceiling?Drywall or plywood?I am looking at green board if I use drywall.
baj is offline   Reply With Quote
Old 01-25-2011, 12:35 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,346
Ayuh,... What's Above those joists,..??
That'll have great bearing on whatever material can be used...
And of course, How it's held there...
Bondo is online now   Reply With Quote
Old 01-25-2011, 01:05 PM   #3
baj
The space above is an attic.Single story house.Very little insulation above ceiling,6" of cellulose.
How to fix bowed ceiling joist? luvdairish Building & Construction 9 11-10-2010 07:02 AM
Mounting ceiling fan with old metal brace, need joist?? nimchimpski20 General DIY Discussions 3 11-09-2010 06:18 PM
Supporting joist under cracked tile JT31 Building & Construction 2 08-26-2010 08:00 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
