Old 01-27-2006, 03:19 PM   #1
expansion joint
quick question. If silicone caulk is put in a 1/4" plywood floor expansion joint where the plywood meets the wall will the silicone compress enough so it doesn't effect the expansion of the wood without pushing up the floor covering?? I'm curious because of a tile floor i'm installing in a bathroom. The plywood subfloor is new and i'm concerned that when water gets into a grout joint and through cement board it could drip through expansion joint and onto ceiling underneath before it has time to evaporate.
farrington135 is offline   Reply With Quote
Old 01-27-2006, 11:02 PM   #2
renovations
expansion joint
The place to stop the water is before it reaches the plywood, not after. If the plywood gets wet it will not dry out, it will rot. Seal the grout. However, to answer your question, the silicone will not cause buckling of the floor.
Sounds like you might be a little light on the substrate for tile, you've got 5/8" or 3/4" plywood sub and then 1/4" plywood? You should really have a minimum of 1-1/4" of plywood in most applications. (Standard 16" o/c joist spacings). Did you already or are you going to thinset under the cement board?
Bonus is offline   Reply With Quote
Plaster to drywall joint question. ERIK2173 Remodeling 7 05-16-2009 05:58 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Advicce on broken joint on wooden frame of chair markhod Carpentry 2 08-11-2007 09:48 PM
Expansion Joints mpt1123@adelphia.net Flooring 4 03-09-2006 06:44 AM
