Expanding A Patio/deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-09-2011, 06:20 PM   #1
Expanding a patio/deck
My house (built in 1889) has a deck on the back that's about 32x7. Most of the deck is attached to the side of the house; the last 6 feet are attached to a patio that's on top of cinderblocks.
I would like to widen the deck by about 6'. I've never done a project like this, but I'm sure I could build a 32x6 deck. I just want to make sure that I understand how to link the addition to the existing structure.
atterlep is offline   Reply With Quote
Old 04-09-2011, 09:22 PM   #2
Pretending to be Retired
I did something similar to what you are thinking of doing. I had Lowe's design the new deck. On mine, the newer section was 2 feet lower than the original since my goal was to lower the handrail so it wouldn't block the view from the great room. I also used glass balusters instead of wood ones so we could see through them. The resultant deck was a huge success with he "boss" of this house.
BigD9 is offline   Reply With Quote
Tags
deck , patio , victorian
expanding foam vs cutting sheets of rigid foam for rim joists Red Squirrel Building & Construction 15 11-24-2010 12:46 AM
Expanding Foam and Radiators limbodog HVAC 1 11-01-2010 05:07 AM
Where to purchase expanding blown-in insulation in Metro NYC area. puparm Remodeling 2 09-05-2008 09:39 PM
framing, expanding wall opening wall - load bearing? nave Remodeling 5 01-23-2008 04:44 PM
Expanding Pex (wirsbo System) DonM Plumbing 1 12-10-2007 07:30 PM
