Old 11-07-2011, 01:36 PM   #16
STAFF
BigJim's Avatar
Expanding Garage INTO house (goodbye Den)
Another thought, you may need to check with the builder of the house to see what strength concrete he used in the part you want to use as a garage. I always had 4,000 mix with wire or rebar and fiber both in the garage concrete. Also the place you want to locate a new weight bearing wall may require a new footing under the slab.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions.
Jim
BigJim is offline   Reply With Quote
Old 11-07-2011, 11:32 PM   #17
Moderator
Yes, the S.E. will call-out the headers, beams, hangers, footings, post bases, post caps, etc. for you, all you need to do is the physical labor---Lol. Scroll down the choices (cursor over the letters) just on top-hangers here: http://www.strongtie.com/products/ca...lange_cwp.html
Let us know the outcome....
Gary
Clothes taking longer to dry?
Gary in WA is online now   Reply With Quote
Tags
driveways, foundation, framing load bearing, garage, load bearing wall
running electric/power from house to garage nexium Electrical 5 06-17-2011 10:49 PM
changing location of electric service to the detached garage from the house. marlowc2 Electrical 3 06-13-2011 12:30 AM
Paint fumes in house from garage burnt03 General Discussion 5 03-15-2010 10:53 PM
Conduit through garage to house. Max wires? RyanD Electrical 12 08-02-2009 06:12 PM
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 08:26 PM
