02-16-2007, 03:47 PM
#1
Expanding foam insulation, where to find it in Nova Scotia?
I would love to have my garage done with the expanding foam you see Mike Holmes use all the time on TV to insulate complicated surfaces but I can't find a contractor that does it, in fact more often then not I can't find one that even knows what I'm talking about. Is it perhaps not approved for use in Nova Scotia or something? I live near Sydney if anyone knows a contractor that can do it.
02-16-2007, 04:55 PM
#2
Many of the expanding foams are not given a "blanket" approval. This is mainly for the 2 part foams because of variability of the final product due to site adjustment, and temperature and humidity factors.
Where the proprietary brands (licenses, franchises, etc.) are not fighting and knocking each other and offer some sort of proof of training or certification, there is more acceptance. - Otherwise is can be on a job by job or city by city approval process.
Competitive insulating materials do not make approvals any easier.
Because there are insulation values required by code, a supplier/contractor must be able to demonstrate that the advertised values can be obtained in all cases. Any ability to affect the product on site makes guarantees very difficult. - Just like the no-no when it comes to adding water to concrete on site.
Often, a national approval does not apply everywhere.
I bring this up because I see it frequently when it comes to approving materials and designs for large areas where there can be variability. What is good in one area may not be as good in another, so it is difficult (and expensive) to get blanket approvals.
02-16-2007, 05:11 PM
#3
Lic. Builder/GC/Remodeler
What you are looking for is ICYNENE, just in case you didn't know what to ask for when you call insulation companies....Outside of that....I can't help you because we are in the States....Maybe someone else....
- Build Well -
02-16-2007, 11:18 PM
#4
Ah, that's the stuff. I assume it comes in other brand names though, the one I've seen used on TV is usually pink or blue.
02-17-2007, 02:41 PM
#5
You're right, the blue stuff is what Holmes usually uses, and it's polyeurathane based - Icynene is white, and doesn't cure up as hard, and it's water-based. Try calling a few insualtion contractors and asking them - theyd be more likely to know someone in town that does spray foam.
06-28-2010, 05:09 PM
#6
Originally Posted by sprayfoam
Advertising info removed
Originally Posted by GOLFERBRC
Advertising info removed.
I have a 1232 sq.ft basement of 2x8 joist in an older home, in Digby Nova Scotia, B0V1A0, half of which is in a 3 1/2 ft. to 4ft. crawlspace; the other half is about 5ft. 8 in. in height, I would like sealed, including the facer boards. could I get an approximate quote, for an R-7 and or an R-14 value, as money is tight do you offer a payment plan.
Thank you
Mr. Higgins
Reason: Advertising info removed
06-28-2010, 05:33 PM
#7
Mr. Higgins,
Please just call the contractors directly at the numbers provided. This forum is not your email system. Everyone can read your messages.
Thanks.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
