Expanding Explosives - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-11-2011, 02:04 PM   #1
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
Expanding explosives
I started a job with a jackhammer, to demolish a large concrete deck, and it's just too damn hot out this year to do that by hand. I looked at the mini excavators but they are very expensive to rent.
Then I started thinking, in mines they sometimes use a special agent where you drill a hole, put the stuff in, add water, and it expands, cracking the rock. I'm sure it would work for cement.
Anyone know anything about this kind of stuff and where I could get it? The nice thing with this is I could use my own hammer drill to make the holes and do it spur of the moment one there's a day it's not too hot out.
Just wondering if this stuff is something a DIY can actually buy and if it would be affective. I'd use this in conjunction with a sledge hammer and metal cut off wheel for the rebar.
Old 07-11-2011, 02:11 PM   #2
joed's Avatar
Rewards Points: 13,298
one brand I found is called crackamite.
http://www.crackamite.com/
Old 07-11-2011, 02:14 PM   #3
Wire Chewer
Rewards Points: 132
I found that too, just can't seem to find anything about pricing or ordering.
Old 07-11-2011, 02:23 PM   #4
Ole Wood Worker
BigJim's Avatar
Rewards Points: 506
Good gravy, if you are going to drill that many holes just get two or three hydraulic jacks, jack the edge of the slab up and pop it a few times with a sledge hammer, it will crack.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 07-11-2011, 02:29 PM   #5
Mold!! Let's kill it!
Rewards Points: 2,012
Looks like Crackamite is only in India. Found this site with an 800 number in the U.S. http://www.dexpan.com/index.aspx Even has prices and looks like you can order on-line. Credit cards accepted. If you get some, be sure to post your results.
Old 07-11-2011, 02:38 PM   #6
Framing Contractor
Rewards Points: 120
We worked on a home recently where the excavator encountered a lot of huge rocks. Started with a jack hammer on the track hoe, and eventually they finished using the silent explosives. I was not impressed with the product. They drilled a ton of holes, injected the stuff, then came back the next day and still had to use jack hammers.
sixeightten is offline   Reply With Quote
Old 07-11-2011, 02:53 PM   #7
Wire Chewer
Rewards Points: 132
The thing with the jack hammer (your way would not work with my slab because it's secured to the house) is I have to rent it, and do it all that day or at least in a few consecutive days (don't get those often) or it gets expensive, if I drill holes I can just drill them at my own leisure when it's not as hot out, or even at night (though it might be kinda loud).
Old 07-11-2011, 02:54 PM   #8
Wire Chewer
Rewards Points: 132
Cool, I'll check that out, thanks.
Old 07-11-2011, 02:56 PM   #9
AGWhitehouse's Avatar
I'm curious the results...
AGWhitehouse is offline   Reply With Quote
Old 07-11-2011, 02:57 PM   #10
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Yeah, Dexpan. Never used it, but there was a thread on it a while back.
Concrete Demolition
Old 07-11-2011, 02:58 PM   #11
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Dexpan expanding mortar
http://www.amazon.com/dp/B000BRPHQ4/ref=nosim/kkorg-20
Those who can, do...
Those who can't criticize on the internet
Mr Chips is offline   Reply With Quote
Old 07-11-2011, 03:09 PM   #12
Wire Chewer
Rewards Points: 132
Amazon.ca does not have it but guess I can still order from the .com, I'll just have to pay the border taxes. I'll have to ensure I order the right amount and make it worthwhile. Border taxes are usually about 100-200 bucks.
I will drill the holes first though, just to see how much of a job that is. My bit always slips in the drill chuck making it harder, I need to figure out a solution for that. I'm wondering if I should buy a bigger drill, like a 1 inch chuck instead of 3/4.
Old 07-11-2011, 03:10 PM   #13
Rewards Points: 5,336
And if you can't, have a next of kin post for you.
I see no down side to this plan. None what so ever.
Ron
B. Franklin 1759
Old 07-11-2011, 03:12 PM   #14
Too Short? Cut it Again!
Concrete Demolition
I remember the thread from not too long ago. The stuff worked fast and well. Hope you can find it. It had great pictures.
Old 07-11-2011, 03:13 PM   #15
Hammer drill might help? Do you have tool rental place? Ask them. Strikes me you might be better off renting something you might not use often again?
expanding foam vs cutting sheets of rigid foam for rim joists Red Squirrel Building & Construction 15 11-23-2010 11:46 PM
Expanding foam for recessed lighting? integlikewhoa Electrical 23 01-18-2010 09:58 PM
cleaning out expanding foam nozzles anervoustwitch Tools 7 08-10-2009 06:30 AM
Expanding Pex (wirsbo System) DonM Plumbing 1 12-10-2007 06:30 PM
expanding foam problem nev1 Painting 2 07-29-2006 09:21 AM
