Existing Slab - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-10-2010, 06:01 PM   #1
Existing slab
Have an existing cover porch. The slab is on a pored foundation. I'm going to be enclosing the porch and I want to install electric radiant floor heating. Should I insualted the slab first or just install the electric radiant over the exisitng slab?
Tim Holmes is offline   Reply With Quote
Old 01-10-2010, 06:42 PM   #2
Registered User
Rewards Points: 5,236
Check with your local Building Department. To convert an outdoor space to a living space may require certain measures. They may want a vapor barrier under the concrete slab, proof of thickened footings to show the slab will support the walls and windows added, a stem wall to elevate the wood and siding off the exterior grade, shear plywood panels in the wall framing to resist lateral and seismic forces, proper size windows for light and ventilation, etc. Notify your Insurance carrier, also.
Be safe, Gary
Building on existing concrete slab JimSpokane Building & Construction 2 07-22-2009 02:19 PM
new slab of concrete over existing jerasmo Building & Construction 7 02-24-2009 08:36 PM
building a pole barn on a existing slab??? scott13676 Building & Construction 3 02-25-2008 07:29 PM
Adding radiant heat to existing slab Seabass HVAC 9 04-27-2007 05:10 PM
