Existing Pad Footing - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-18-2010, 08:51 AM   #16
I guess to be sure it won't drop means proper compacting? Should I encase the pipe in a 2x6 box during the pour? That would mean doing the pour in 2 shots first pour up to just under the level of the pipe then wait until the concrete hardens a little (10-12 hrs as per Quikrete) place my box over the pipe and complete the pour....sounds good?
ojee001 is offline   Reply With Quote
Old 12-18-2010, 08:59 AM   #17
Concrete & Masonry
Rewards Points: 548
No, if anything just wrap the pipe in 1/2" expansion material. It's sold in rolls of 4" or 6" by 50' at most big box stores.
jomama45 is offline   Reply With Quote
Old 12-18-2010, 09:02 AM   #18
Rewards Points: 5,336
I don't understand the box thing. Any wood you place will compromise the footing for the pole. The fact that you have a 4" pipe going through the footing may compromise it.
Check with the engineer who spec'ed the footing. The pipes situation may make the footing useless in it's projected space.
Ron
join new crawl space CMU footing/foundation to existing CMU basement wall CapeCod153 Building & Construction 4 08-04-2010 07:35 PM
Adding a footing to an existing slab on grade jascox Building & Construction 4 07-05-2010 02:20 PM
How to add footing and foundation to existing foundation? ptcamaro Building & Construction 6 06-22-2009 10:22 AM
Footing for Block ontop of existing Fieldstone foundation. Concerns w/ work done.. slowjo Building & Construction 6 04-26-2009 10:17 PM
Wrong Footing Dimensions HELP jhernan35 Building & Construction 2 04-15-2007 02:22 PM
