Excavate For Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-08-2011, 10:46 PM   #1
Question
excavate for foundation
I'd like to start a discussion on some ideas, techniques and options raising a house above grade for installing a concrete foundation for a 3 feet crawl space.
Let's assume the house exists on grade, measuring 28 x 28 feet and has to be raised 2 feet. There is no rot, solid ground and house is in good condition.
What is involved with excavating a trench for the (concrete) foundation with the house raised 2-3 feet? Even with a small machine it is difficult to dig a trench close to the house. Digging by hand is one option.
I have a restricted space for manovering machinery.
Len
jeffjocegus is offline   Reply With Quote
Old 01-13-2011, 08:16 AM   #2
Stay-at-home GC
Lots to talk about. Pictures would be a good start. Current foundation?
Can correctly identify Shinola 3 out of 5 times*
*Under ideal conditions
Some days, my Life needs a Rewind/Erase Button.
CplDevilDog is offline   Reply With Quote
Old 01-13-2011, 04:37 PM   #3
Not what you want to hear, but I once saw a house being excavated by the homeowner. It was up on cribbing until he backed his bobcat into the cribbing and the house fell in the hole. It remained at a 458 angle until the local authorities condemned it. Was a really nice house too!
mrgins is offline   Reply With Quote
Old 01-13-2011, 04:42 PM   #4
Experienced
Jackofall1's Avatar
Raise the house onto 4 - 60 ft steel skids, slide the house out of the way, do the foundation, slide the house back over the foundation and lower. Remove skid and finish foundation in areas where skids were.
Old 01-13-2011, 04:47 PM   #5
Seems a shame to do all that work and not go with a full basement
Old 01-13-2011, 04:49 PM   #6
Stay-at-home GC
Very concise.
Old 01-14-2011, 09:08 AM   #7
Mold!! Let's kill it!
Rewards Points: 2,012
Probably be easier to excavate a full basement under it than a 3 foot crawlspace. You'd only need access on one side and work the rest of the excavation from underneath. Pouring footers and building walls would certainly be easier.
Old 01-14-2011, 07:56 PM   #8
Rewards Points: 150
Yes, it can be done, and I'm thinking along the lines of doing the corners first in concrete block, stair stepped, up to the height you want, with wire in the mud. You can even lay two courses of block all around the house, then rent panels or buy plywood and rip so you'll have 2x8 lengths to work with. You can jack the house up a little at a time ,like in inches. If your floor joists and band boards are in good shape you'll have no problem, but focus on good support on solid earth underneath. If you never poured walls before ,be sure you have plenty of wall wire loops with rods running through and plenty down low. Even threaded rod works for the 8 inch way. A small roto tiller will help in the digging. This is based on a nearly flat lot. A good job for a dry August.
bernieb is offline   Reply With Quote
