Evidence Of Water Seepage On Cinder Block Wall-action To Take Before Finishing B'ment - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-21-2013, 03:16 PM   #1
Evidence of water seepage on cinder block wall-action to take before finishing b'ment
Hi. This is my first post. I am planning to tackle finishing the basement in our house; in the middle of clean-up, and noticed this. The house was built in the 60s, and I suspected that this is a result of water pressing up against the wall from roof water run-off. The eavestrough on the front of the house is pulling away and lets water dump near the foundation (roofer is already signed-up, but we need to wait for warmer weather). There is a sump pump near this area that does work, but never runs (ie not enough water to activate float switch). There is no water ever present on the basement floor.
I have had a wet-basement guy in who has suggested installing a product where they remove 10" or so from the concrete floor, install "foundation guard" which channels water to a sump pump, and then repour the floor over top. This is quoted at $4300, and is to solve for water pressing up from beneath that is believed to be wicking up the wall. I cannot tell if this is a continuing process, or if it will be cured by the new eavestrough and making sure the water is dumping the well away from the foundation. Also I am considering either 1" closed cell foam adhered to the basement walls, or spray foam, and wondering whether either of those will form a sufficient moisture barrier that I do not need to pay the $4300 for the foundation guard. Sorry for the long post, but I have no experience/knowledge on this kind of topic, and looking for opinions.
Thanks!
Jeff
Evidence of water seepage on cinder block wall-action to take before finishing b'ment-img_20130221_151340-1-.jpg
jheyerman is offline   Reply With Quote
Old 02-21-2013, 03:43 PM   #2
MarginallyQualified
Rewards Points: 2,464
I have had a wet-basement guy in who has suggested...
This is quoted at $4300...
Er... no.
Long story short... postpone the basement remodel until the fall.
Meanwhile do all the plain vanilla "how do I direct rainfall water away from the foundation" work*. Also... scrub brush that efflorescence off of the block walls then repaint.
Do the work. Watch what happens when it rains this spring.
*Links: http://goo.gl/yei3Z
Old 02-21-2013, 06:05 PM   #3
Rewards Points: 4,442
can't tell if that's paint, blockfiller, or drylock-style products,,, the sub-floor perimeter drain not only catches wtr coming UP under the footer & up thru the base fill but drains the cells/webs of the blocks,,, you'd probably need a sump & pump to discharge the collected leaking wtr.
there isn't any coating that will resolve your problem,,, IF there were, your bsmt wall would eventually implode & collapse from the damage that's occuring but you just can't see it
' foundation guard ' = ' french drain ' - we charge $ 50 / $ 75 per lf + $ 1,300 for sump, ck valve, & Zoeller 1/3hp pump - min job's $ 2,250,,, this is not only my personal opinion but my professional evaluation as well
ps - IF drylock products really worked, we wouldn't have ANY business at all
Repair pitting in cinder block wall.... stupid48 General DIY Discussions 10 02-01-2012 01:06 AM
What can you do to a Cinder Block wall? PTE8 Building & Construction 2 10-06-2011 02:06 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Cinder block wall 3DPiper Building & Construction 1 03-28-2007 12:32 PM
Hanging cabinets on cinder block wall ponchoman1 Remodeling 2 04-25-2006 10:34 PM
