Ever Heard Of A Melamine Beam? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 09:49 PM   #1
Ever heard of a Melamine beam?
Ever heard of a melamine beam? If they exist, are they strong and where can I find span charts?
crhage is offline   Reply With Quote
Old 08-04-2011, 06:15 AM   #2
Melamine is a thin plastic, usually over particle board. It has the structural strength of spaghetti, so i doubt you could make a beam from it.
Perhaps you could tell us what you have in mind????
Old 08-04-2011, 06:25 AM   #3
Man of many hats
wrangler's Avatar
Rewards Points: 354
Maybe an LVL beam? Laminated-veneer-lumber...
Man of many hats
wrangler is offline   Reply With Quote
Old 08-04-2011, 07:39 AM   #4
Civil Engineer
Rewards Points: 4,938
Have you ever heard of a melamine beam?
Chinese and plastic, quite the team
They put it in dogfood, what a scream
But too weak for structural, I would deem
Old 08-04-2011, 08:10 AM   #5
Not so new
12penny's Avatar
Rewards Points: 520
And a poet as well!
12penny is offline   Reply With Quote
Old 08-04-2011, 08:15 AM   #6
Rewards Points: 150
I'm pretty sure I read somewhere that they use melamine resins in adhesives for osb sometimes.
OP, can you be more specific as to what you mean by melamine beam?
Broughton is offline   Reply With Quote
Old 08-04-2011, 08:32 AM   #7
Rewards Points: 150
I realized in my eagerness to be helpful and decipher the OP's meaning I made a ridiculous connection.
Referring to a beam by an ingredient in the glue that holds the web together is on par with calling a car a weld wagon.
Old 08-04-2011, 01:24 PM   #8
Broughton you're killing me...
Ok, sorry for posting that ridiculous topic. The contractor I was speaking with said Microlam and not melamine. No wonder I was confused. Melamine is what the Chinese were putting in dog food a few years ago. It is also a glue used in some construction applications.
So, what about microlamb. Any issues with using a microlam beam over a span of 18 feet?
Old 08-04-2011, 01:40 PM   #9
Rewards Points: 150
Ah, that makes more sense! Microllam is a brand of lvl (laminated veneer lumber). There are different sizes so I can't flat out tell you that a beam of that will span 18' but there are lvl beams that can span 18'.
Old 08-04-2011, 01:48 PM   #10
12 inch microlam I believe is what he is using. wrapping that in cedar.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 09:06 AM
How to repair main support beam Jerry48ece Building & Construction 0 01-08-2011 08:38 PM
Main Beam De-Laminating Bird Doo Head Building & Construction 6 12-09-2010 12:08 PM
Crawl Space Beam and Joist Support Questions Fire4Effect Building & Construction 5 06-28-2009 01:07 PM
Beam Replacement? Steve Dailey Carpentry 5 05-19-2008 08:46 PM
