Eroding Bricks - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-15-2009, 07:15 AM   #1
Eroding Bricks
My mom's home is about 30 years old and is all brick. It is in Florida. The bricks are white and I guess they were "used brick" as the corners are rounded or at least not perfectly square. Anyway, in some places they are eroding and all that is left is the mortar between them. It is hard to determine the exact cause, as some are where a sprinkler has hit them repeatedly over the years, others are where mold or mildew might be the culprit, but others are just eroding. We have been told that perhaps they weren't Fired at the optimum temperature when they were made...but not sure.
Anyway, I am attaching pictures of the problem and would love to have suggestions as to how to go about fixing it. I don't think it is a structural problem, as the house is framed behind the brick..but would like it to not be an eye sore, or obvious mess. Thanks in advance.
Eroding Bricks-dsc00930-large-.jpg   Eroding Bricks-dsc00931-large-.jpg   Eroding Bricks-dsc00932-large-.jpg   Eroding Bricks-dsc00933-large-.jpg   Eroding Bricks-dsc00926-large-.jpg
mfwilkins is offline   Reply With Quote
Old 02-15-2009, 08:43 AM   #2
Chicago, IL
Michael Thomas's Avatar
If that brick was spalling I would suspect the builder used MW grade brick in an area with a freezing conditions, but that looks as though it's "dissolving" - perhaps sub-standard brick from Mexico, or a locally produced product intended for decorative indoor use? In any case the veneer will likely need to be entirely rebuilt, or covered with another cladding material.
Michael Thomas is offline   Reply With Quote
Old 02-15-2009, 11:05 AM   #3
Rewards Points: 5,336
This doesn't look like a full brick. It looks like it's only an inch or so thick, unless the pictures are distorting my depth perception.
The issue seems to only be in that corner where there is definite evidence of moisture.
Fix the sprinkler system and call in a mason or two for a solution.
Ron
Old 02-15-2009, 11:31 AM   #4
Rewards Points: 1,232
Low fired brick and moisture. Remove the source of moisture, cut out the bad brick and replace.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
dissipating mortar b/ween bricks amakarevic Building & Construction 7 01-02-2009 05:36 PM
Damp, Crumbling bricks & Blown Plaster crscrs Building & Construction 2 10-02-2008 05:20 PM
Problem with bricks in fireplace box pulling away from interior wall proofer Building & Construction 1 06-15-2008 07:54 AM
painting the bricks around the burner debz Painting 3 01-28-2008 06:22 AM
