Old 09-06-2012, 12:09 AM   #1
Erect wall on concrete slab
I want to expand an existing room into my garage which
has a 4" concrete floor. The wall will not be load
bearing. Is the concrete floor a sufficient foundation???
DOUG HEINZER is offline   Reply With Quote
Old 09-06-2012, 12:17 AM   #2
Yes, just make sure you use 5/8 fire code sheetrock on the outside walls if the area is still gong to be a garage.
Old 09-06-2012, 08:16 AM   #3
GBrackins's Avatar
I agree with joe. I would add to double check with your building official and make sure they have no issues with that, and if you need a building permit. I'm sure you'll be moving electrical into the new wall and that typically will kick in the permitting. Permitting requirements can vary from state to state.
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is online now   Reply With Quote
Old 09-06-2012, 12:11 PM   #4
DIY-er
The garage in our house was converted to living space before we moved in. The only issue is that the floor (hardwood on top of the concrete slab) is very cold. I would highly recommend installing floor heating with insulation before laying down the hardwood or tile, according to the building code requirements in your area, if a cold climate is an issue in your area.
If you are making changes to load bearing walls and installing electrical, you may need building and electrical permits, and if you installing a kitchen you will need plumbing permits. As another person indicated, its best to check the building code in your area. Building without permits can result in your insurance company not covering you in future.
KevinPh
KevinPh is offline   Reply With Quote
The Following User Says Thank You to KevinPh For This Useful Post:
GBrackins (09-06-2012)
What's Happening on my Slab? chew Flooring 6 04-10-2011 01:11 PM
my concrete retaining wall has a major crack where the wall has now shifted DanDaMan Building & Construction 1 04-02-2011 12:34 PM
A glue that works on precast concrete wall wildwings Building & Construction 5 12-30-2010 09:34 AM
Pouring Concrete Slab in a small rickety garage. RORO Building & Construction 0 10-19-2010 04:56 PM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
