Equipment Grounding - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-18-2011, 01:11 AM   #1
equipment grounding
is it good to used corrugated rebar for equipment grounding?
rolan is offline   Reply With Quote
Old 06-18-2011, 08:25 AM   #2
Rewards Points: 5,336
No, it will rust and the rust will insulate the connector from the wire and you will lose your ground.
Ground rods are copper for a reason.
Ron
B. Franklin 1759
Grounding rods for tv antennas Wasatch Rebel Electrical 4 06-02-2011 08:23 AM
Range Outlet Receptical Wiring - PICS nave Electrical 45 05-29-2008 07:37 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 06:45 PM
advice on installing equipment grounding bar in main panel pacifier1er Electrical 5 05-29-2007 06:55 PM
