-   -   epoxy coating for waterproof deck (http://www.diychatroom.com/f19/epoxy-coating-waterproof-deck-51589/)
Jeremy Hillary Boob, PhD 08-24-2009 03:27 PM
I want to create a carport below part of my redwood deck, but I don't want to spend a fortune on it. I have seen the aluminum systems and such (lockdry, duradeck, etc.) and they are too expensive. Instead, I plan to remove the deck surface, put down 1 1/2 inch of plywood, then cover with an epoxy coating to create a waterproof surface. Several neighbors have done this over garages, and I realize it doesn't look as nice as a "real" deck surface, but it'll be acceptable for us. So, my question is, does anybody have experience using any of the epoxy coatings in this kind of application? I've found several different products online (Sonoguard Deck Waterproofing is one example), which vary widely in price, but I can't seem to find any unbiased info on which are better. None of the neighbors can recall exactly which brand they used. Thanks.
JCroc 08-26-2010 03:03 PM
Hey There,
Epoxy coating is a good solution for waterproofing decks and concrete surfaces. Although, ply wood is a very porous and epoxy may not be the best solution to your problem. Another good option you may want to look into would be the various deck sealers that they offer in hardware stores. Just make sure that it would be the best thing for your problem. :)
Best Regards,
John
industrial epoxy flooring|epoxy floor coating
stadry 08-26-2010 03:41 PM
if you weren't such a boob :laughing: you'd have said where you live so responses could consider expansion/contraction,,, epoxies aren't uv-resistant however many coatings are,,, your biggest issues will be the proper prep & mtl selection.
i don't know of ANY mtls found at any apron/hardware store,,, look at a commercial contractor supply house instead.
Maintenance 6 08-27-2010 06:33 AM
Epoxies are hard and brittle. They don't take well to expansion and contraction. They also don't breath much. To waterproof a wood surface, you should look at an elastomeric coating that can move a little bit with your wood substrate.
