Epoxy Coating A Garage Floor? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-11-2007, 08:52 AM   #1
Rewards Points: 562
Epoxy coating a garage floor?
Does anyone know anything about this? Are there different types of coatings? Which are the best? About how much would epoxy coating a 2-car garage (19 x 21) run?
kcrossley2 is offline   Reply With Quote
Old 09-11-2007, 11:28 AM   #2
I've used the 1 part Behr Epoxy and Like it. Prep work is the key with any on them. i Did a 12 x 24 for about 60 bucks in Mat'l (prep stuff included) already had the pressure washer
mdlbldrmatt135 is offline   Reply With Quote
Old 09-11-2007, 01:02 PM   #3
HandyMan Engineer
Epoxy
I just did mine this past spring. Used a two part epoxy with 70% solids. You can go higher but its tougher to work with. The product was from cloverdale paints. I used 4 single gallon pails to do two coats on a 22x24 garage. Make sure you get the same colour batch. Basically I did half the garage, then the other waited a couple of days and did the second coat. You can't too long between coats or you won't get a good bond (max 7 days I think). I also recommend a carbon filter half mask, though the pink elephants were nice.
sendres is offline   Reply With Quote
Recommendations for finishing garage floor? bhpizza Flooring 30 01-28-2011 10:09 PM
Blacktop on Garage Floor?? terrypearson Flooring 3 08-06-2007 07:05 AM
Staining a garage floor? Ledge General DIY Discussions 5 07-10-2007 03:57 PM
Raising Garage Floor to match House Floor felice_oggi Building & Construction 2 09-22-2006 07:26 PM
Garage Floor leveling. Marsharo Remodeling 1 12-30-2005 02:11 PM
