Entry/exit Building Code - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-12-2012, 11:10 PM   #1
noshoff
Post
entry/exit building code
What is the building code that addresses the number of entry/exit openings from a bedroom. This room is located on the lower level of a split level house where there is a walkout basement. One wall of the bedroom is an exterior wall with a doublehung window. Another wall has a stairway on it's other side. A third wall is below grade and has solid concrete floor to ceiling. The last wall has a door into a 5 foot long hallway leading to a room with windows and a door to the outside and a door to the ground level garage.
shadowbuilder is offline   Reply With Quote
Old 01-12-2012, 11:14 PM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
That window needs to be so many square feet or a minimal open measurement. Check local fire code.
Sent from a Samsung Galaxy SII
titanoman is offline   Reply With Quote
The Following User Says Thank You to titanoman For This Useful Post:
mae-ling (01-12-2012)
Old 01-12-2012, 11:24 PM   #3
Rewards Points: 12,804
http://www.truss-frame.com/window-egress.html
Local codes may differ.
Old 01-12-2012, 11:27 PM   #4
Rewards Points: 2,202
That differs then our code here in Canada
mae-ling is offline   Reply With Quote
The Following User Says Thank You to mae-ling For This Useful Post:
shadowbuilder (01-13-2012)
Old 01-13-2012, 12:57 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
I can't say that I understood exactly what you have there but, If there is a door to the outside you do not need to make a window comply with egress as the door already does that.
Is that the question?
Andy.
AndyGump is offline   Reply With Quote
Old 01-13-2012, 01:10 AM   #6
Disabled wood vet
titanoman's Avatar
Andy.
You sure do here. And the window has to be like at least a 3- 4 w/ half of it opening, and a 32" door.
(unless the door is actually a door to the outside, which isn't this case).
(though I'll be honest I don't know what egress is).
Old 01-13-2012, 01:20 AM   #7
As I understand the OP the stairs are on the other side of the wall
Old 01-13-2012, 01:22 AM   #8
AndyGump's Avatar
Rewards Points: 660
But do the stairs go directly to the outside or what?
Andy.
Old 01-13-2012, 01:30 AM   #9
Disabled wood vet
titanoman's Avatar
Sounds like the only door goes into another room with windows and a door.
Er rather a hallway with a door.
Old 01-13-2012, 01:35 AM   #10
The way I read it it is a standard bedroom with a double hung window and a doorway which is off a hallway.
The window needs to be fire egress.
Old 01-13-2012, 07:49 AM   #11
Mold!! Let's kill it!
Rewards Points: 2,012
It would depend on what building code your municipality has adopted. Typically, since the door does not lead directly to the outside, there is a requirement for a second means of egress. That would be the window. There is a minimum square foot dimension for the opening when the window is in the fully opened position and a minumum linear dimension of the opening measured at it's narrowest point. There is also a maximum height from floor to sill. You need to find out which code you must follow.
Old 01-13-2012, 12:20 PM   #12
noshoff
You put me on the right track. I'll check about a second egress. Thanks Maintenance 6.
Old 01-13-2012, 12:25 PM   #13
noshoff
Thank you AndyGump. The stairs are on the other side of one of the bedroom walls of this splitlevel house. There a 36" wide door opening to a 36" wide hallway 6 foot long. The hall leads to a room with 2 doors and 2 doublehung windows on the outside wall.
Old 01-13-2012, 12:32 PM   #14
Disabled wood vet
titanoman's Avatar
What about the other people that took the time to help you?
Old 01-13-2012, 12:33 PM   #15
noshoff
I am trying to avoid constructing an other door into this bedroom. Looks like if the window is the proper egress I can . Thanks for your read.
building a main and sub panels for 2 remote buildings n175h Electrical 30 12-20-2011 03:09 PM
Simplified/Summary CA Building Code? acerunner General DIY Discussions 5 03-18-2010 10:46 PM
Finding a copy of the 2006 International Building Code WFO Electrical 2 07-11-2009 08:21 PM
Handrail building code questions - Canada Peterpantz Carpentry 7 10-26-2008 01:24 PM
Buidling code for deck and nailing schedule Jozee Building & Construction 7 10-01-2008 01:46 PM
