Entry Door With Sidelights - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-07-2010, 09:04 PM   #1
entry door with sidelights
do you HAVE to replace door AND sidelights in an entry door? I ike the sidelights we have but need a new door..\
thanks for any help
scottandkristy2 is offline   Reply With Quote
Old 11-08-2010, 12:38 AM   #2
jlhaslip's Avatar
Rewards Points: 2,140
Nope.
The door jamb and sidelights are typically nailed/stapled together.
If the jamb is good, you can purchase the door slab separately.
It will be quite a chore to change out the door jamb though.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is online now   Reply With Quote
Old 11-08-2010, 05:36 AM   #3
to add: generally, the weathstripping in new doors is far superior to an older door frame. And the glass is more energy efficient. Yes, you can change just the door(and considerably less expensive), but it might be better to replace it all as a unit.
Old 11-13-2010, 01:55 AM   #4
You can still just get a door and fit it to the jamb. If you go to a door supplier there are a lot of options for what you could get. There are also plenty of weather striping options that can be installed in place.
It used to be that every door was fit on site. Believe it or not it can still be done today.
Portlandtrades is offline   Reply With Quote
Old 11-13-2010, 08:19 AM   #5
Rewards Points: 5,336
Just realize that if you want a fiberglass or steel door, the size adjustments on site are practically non existant. These doors should be prehung and set in their entirety.
Ron
Front Entry Door Paint/Color Advice gibear2k5 Interior Decorating 23 08-30-2010 04:52 PM
Timing for rebuilding of side entry: Help! navi_jen Remodeling 0 06-16-2010 10:02 AM
*Pics* Entry way tile designs needed ConstantChange Tiling, ceramics, marble 4 08-03-2009 11:22 PM
Finishing unfinished entry door Clutchcargo Painting 9 06-18-2007 01:22 PM
