Entry Door Gap Problems Advice Needed - Building & Construction - DIY Chatroom Home Improvement Forum
Old 08-04-2010, 04:23 PM   #1
Entry door Gap problems advice needed
Ok I have two doors that are giving me problems with the gap. The top of the doors on the handle side hits the frame thus not allowing the door to close properly, and the gap is tight up top and a little wider than I'd like on the bottom. its not too bad but its annoying. I installed these doors and when I did they closed great and had an equal gap on the latch side. Is this a junk door or should I just reattempt to sink the top screws on the hinge side?
jhayes is offline   Reply With Quote
Old 08-04-2010, 04:30 PM   #2
kwikfishron's Avatar
Rewards Points: 596
Have you replaced one of the upper hinge screws with a 3” screw that will make it into the framing?
kwikfishron is online now   Reply With Quote
Old 08-04-2010, 04:35 PM   #3
Originally Posted by kwikfishron View Post
Have you replaced one of the upper hinge screws with a 3 screw that will make it into the framing?
Yes i always install 1 or 2 long screws into each of the hinges to replace the short factory screw. I will double check when i get home to make sure I didn't get into a hurry and forget to get the top one.
Old 08-04-2010, 05:18 PM   #4
KemoSabe
loneframer's Avatar
A long screw into the framing at the top hinge should solve part of the problem. If the bottom margin is still unacceptable, an easy fix is to shim the hinge leaves with a playing card thickness or two.
There is a better way, but it's more involved.
loneframer is offline   Reply With Quote
Old 08-04-2010, 05:25 PM   #5
Check that the door is not out of square by comparing diagonal measurements.
Old 08-04-2010, 05:54 PM   #6
thanks for the reply's. I will report back on the success.
Needed basement advice... gripp2020 HVAC 4 11-28-2009 11:43 PM
Switching from old Oil Heating system, advice needed captainobvious HVAC 2 09-29-2009 01:18 PM
Entry Door installation... Advice needed! mburgess44 General DIY Discussions 19 09-12-2009 07:46 PM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
bathroom floor tile job advice needed dbrew Flooring 14 01-23-2007 07:03 PM
