Enlarging Exterior Door In Block Wall. - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-15-2011, 10:10 PM   #1
enlarging exterior door in block wall.
hello, i want to cut into a belgian block wall to enlarge a doorway.
has concrete header/lentil. any advice? thanx much
doitmyself123 is offline   Reply With Quote
Old 03-16-2011, 01:18 AM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Not too sure but do you need a Belgian to do it?
Andy.
AndyGump is offline   Reply With Quote
Old 03-16-2011, 01:30 AM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
well, your lentil is going to have to be wide enough to cover the new opening. It also, obviously, has to be strong enough to support the load. There are a few guys here that are masons and a few others that will likely have some info.
How big is the current opening? How big do you want the new opening to be? How tall is the wall this opening is in? What is below this wall?
Old 03-16-2011, 11:20 AM   #4
Rewards Points: 3,130
Lentils make good soup. Lintels are much better for doorways.
Old 03-16-2011, 01:07 PM   #5
nap
You talking to me?
nap's Avatar
I suppose so. I seem to make that error with regularity. One would think I would learn that by now...
but if I did, there would be no comedic relief available in threads concerning lintels.
Or I could have blamed it on the dsleiaxy I don't have.
Basement Block Wall Cracked JoeLena Building & Construction 8 12-16-2010 06:39 AM
How to attach insulation panels to block wall BRO931 Building & Construction 3 10-29-2010 05:01 PM
2.5 to 3 ft ht standard block wall cprao Building & Construction 5 07-31-2010 12:11 PM
What to do with windows when firring out from a block wall. willemdejong Carpentry 1 06-04-2010 12:25 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
