Enlarding A Hole In Firebreak - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-27-2009, 10:00 PM   #1
Low Voltage Fun
Enlarding a hole in firebreak
I've got a 1/2" hole in the firebreak that I need to increase to 1" to accamidate wires.
My problem is bellhanger bits only go up to 1/2" and trying to get a self starting bit going in a preexisting hole is a bear - especial when you can't see what you're doing...
Any suggestions on what type of bit (w/48" extension) to use?
Thanks!
winesmile is offline   Reply With Quote
Old 01-28-2009, 12:26 AM   #2
Registered User
Termite's Avatar
By "firebreak" I assume you actually mean firewall. Let me first say that you should never, never drill into a firewall assembly unless you are capable of properly firesealing the penetration. Firewalls are listed, as are the individual penetrations, and must be done in a very certain way in order to maintain fire resistance. Intumescent firecaulk would be appropriate, but if you can't get closer than 48" to the hole there's little chance that you'll be able to properly firestop the penetration.
1" flexible installers/bellhangers bits are available at most home centers in lengths around 5'. They're intended for drilling holes in plates for cut-in boxes in sheetrocked walls, but would work great for your application. They're flexible but not droopy if that makes any sense...They only flex when you bend them. Greenlee is one manufacturer of such bits.
Old 01-28-2009, 12:32 AM   #3
Low Voltage Fun
Great thanks. I was also looking the Rebor-Zit by LSD. The have them 3/4" to 1" as well.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
A Hole to Nowhere fw2007 Electrical 12 03-24-2008 11:28 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
Tool to deepen deadbolt hole? darsunt Carpentry 5 07-18-2007 11:45 PM
Making an 8" hole in the brick Hushpuppy Building & Construction 6 11-28-2006 08:17 AM
