End Gable Soffit Question - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-29-2013, 05:48 PM   #1
End gable soffit question
Hello,
When you have your end gable soffit j channel that holds in the soffit against the gable wall and lets say you want to add vinyl siding or vinyl shake siding underneath for the end gable wall. Below the soffit J channel do you just "but up" another piece of j channel for the siding or should you have a piece of flashing between the two pieces of j channel? Reason I am asking is because if you have the two pieces of j channel up against each other wouldn't that be a spot for water to get in?
markharmon is offline   Reply With Quote
Combining Gable and Soffit vents Shabby Insulation 10 10-08-2011 04:57 PM
Question about installing soffit vents RST Roofing/Siding 9 07-18-2010 08:15 PM
Soffit Vent Vs. Gable Vents? coopns Roofing/Siding 0 05-13-2010 09:43 AM
Installing Soffit and Facia??? Vikeologist Roofing/Siding 3 11-15-2006 05:01 PM
Question re: fiber-cement soffit material MichaelinOmaha Carpentry 4 10-12-2006 07:30 PM
