Hello,
When you have your end gable soffit j channel that holds in the soffit against the gable wall and lets say you want to add vinyl siding or vinyl shake siding underneath for the end gable wall. Below the soffit J channel do you just "but up" another piece of j channel for the siding or should you have a piece of flashing between the two pieces of j channel? Reason I am asking is because if you have the two pieces of j channel up against each other wouldn't that be a spot for water to get in?
