Enclosing Poles Within Framing - Building & Construction - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 04:43 PM   #1
Enclosing poles within framing
Hey everyone,
I have a couple metal support poles running in my basement where I want to run a wall across. My initial though was to put the wall in line with the pole and enclose it within the drywall, however it seems that the pole is about 0.5" wider than the 2x4 stud. My initial thought was to build a wall/frame on either side, and have a 4" gap between the two frames, but there will be a door in that wall, and the prehung door won't fit into that space then because of the extra 4".
Anyone have any other ideas? I'm thinking right now my only option might be to just frame around the pole sort of like a pillar.
Thanks.
dstylez is offline   Reply With Quote
Old 03-09-2009, 05:46 PM   #2
Rewards Points: 342
When we framed-in the steel supports in our basement, we used 2x6's instead of 2x4's to build that wall.
gma2rjc is offline   Reply With Quote
Old 03-09-2009, 05:55 PM   #3
Remodeling Contractor
or use the 2 X 4 wall and jog out around the posts to make them look like columns.
Old 03-09-2009, 08:22 PM   #4
My only problem with that is that a standard door wouldn't fit into that wall then.
I think I might have to make them into columns.
Old 03-09-2009, 09:50 PM   #5
You can always buy a 2x6 jambs.
choda_boy_04 is offline   Reply With Quote
Old 03-10-2009, 06:15 AM   #6
Or you can extend the door jams. This is done all the time.
Old 03-10-2009, 06:58 AM   #7
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
1. Build out the wall to match the tnickness of the steel columns.
2. Cover the columns with something more tasteful.
3. If doing option 1, you can ferr(sp)-out (extend) the door jamb on one side.
Picture Example of option 2 (wood column covers):
Picture Example of option 3 (Ferring-out/extending the jamb):
- Build Well -
Old 03-10-2009, 11:10 AM   #8
^ Awesome!
Thanks for the pics Atlantic!
How do I find a framing contractor in Rhode Island christy123 Building & Construction 2 10-25-2006 11:29 PM
Framing Gun - Nail Shank Diameter Questions... MoparAutoworks Building & Construction 5 07-03-2006 10:27 PM
Wood Framing Getting Wet? stagger19 Carpentry 2 05-10-2006 09:37 AM
Framing a 16 foot high wall for shop pranderson Building & Construction 10 01-01-2006 05:23 PM
