Enclosing Loft With Glass Windows? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 12-18-2006, 06:34 PM   #1
Rewards Points: 556
Enclosing loft with glass windows?
How feasible is it to turn a loft into a sound proof room using large floor to ceiling windows similar to what you'd find in a contemporary office? Will the floor handle that kind of weight?
kcrossley2 is offline   Reply With Quote
Old 12-28-2006, 07:22 AM   #2
What is the size of the beam under the loft?
How large is the opening that the windows will be placed in?
redline is offline   Reply With Quote
Old 12-28-2006, 09:39 AM   #3
Rewards Points: 109
weight
Glass is heavy - glass made with the idea of sound proofing is even heavier (much!). If the loft was not specifically designed to hold additional weight across the open area then I wouldn't even consider the possibility of adding a glass wall there without an engineering inpection and load determination first.
oberon is offline   Reply With Quote
terrible windows mt232 General DIY Discussions 10 12-28-2008 05:37 AM
Replacing Glass In Windows OVRMYHEAD General DIY Discussions 1 04-26-2007 06:07 PM
Plate glass windows in 2nd floor loft? kcrossley2 Building & Construction 9 04-01-2007 07:29 PM
How do I install new windows? RickT Carpentry 17 10-12-2006 06:06 PM
Glass Block windows... daveincincy General DIY Discussions 1 07-18-2006 10:08 PM
