Enclosing Crawl Space With Brick - Building & Construction - DIY Chatroom Home Improvement Forum
Old 07-28-2011, 10:25 PM   #1
enclosing crawl space with brick
My house is on pier and beam. I would like to enclose the crawl space with brick to provide more attractive appearance. I have been advised this is a bad idea due to propensity to rot the floor joists. I've seen it done on many houses in the south with decorative blocks to provide ventilation. Is this a bad idea? What are the alternatives?
cunnyngham is offline   Reply With Quote
Old 07-29-2011, 10:13 AM   #2
Rewards Points: 5,336
I would seal the ground under the house with a vapor barrier and provide vents in the brick. If need be, install a fan hooked to a humidistat to keep the humidity level equal to the exterior if you see the humidity in the space getting elevated.
Ron
B. Franklin 1759
Old 07-29-2011, 10:37 AM   #3
brick in crawl space
I'm not planning on enclosing all 4 sides, only the front side initially and then maybe the back side if it looks good. Do I still need to install some type of barrier or will the other 2 sides left open provide adequate ventilation? Thanks for your advise.
Old 07-29-2011, 10:57 AM   #4
The advice was based on the post that you were enclosing the crawlspace.
You are not enclosing the crawlspace, so you do not need to do anything with one or two walls, as there will be adequate ventilation.
Ron
B. Franklin 1759
Water in crawl space after it rains and other questions about crawl space. dupaloop General DIY Discussions 1 04-13-2010 06:58 AM
Crawl Space Questions (with pics) burnt03 Building & Construction 4 11-04-2009 07:44 PM
Insulating crawl space jenoble99 Building & Construction 10 06-18-2009 01:09 PM
insulating crawl space near plate measure thrice Building & Construction 13 01-26-2009 04:11 PM
Crawl space venting... MLO Building & Construction 2 09-23-2006 04:18 PM
