Encapsulated Styrofoam - Building & Construction - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 02:31 PM   #1
Encapsulated styrofoam
I am one of the owners of a family dock. The dock itself is made of up metal pipe with the older strofoam underneath keeping it afloat. The problem is, apparently we have a family of beavers that is chewing the styrofoam and living under the dock. It is steadily sinking a little at a time. The corp here says encapsulated styro is the only acceptable form of floatation. Where would I find this? And how many manufacturers of this product are out there??
tupplady1 is offline   Reply With Quote
Old 01-07-2012, 03:21 PM   #2
Rewards Points: 1,092
I have seen plastic pontoons holding up docks; just big water jugs, sans the water inside. Are these not acceptable in your area? I have no idea if they are beaver proof.
Old 01-07-2012, 04:20 PM   #3
retired union carpenter
Send a message via Yahoo to coupe
ever use google?
http://www.wholesaleez.com/search.ph...-styrofoam.php
as always, just my thoughts
good luck....coupe/Larry
take what helps? ignore the rest.
coupe is offline   Reply With Quote
What kind of adhesive to use on Styrofoam insulation? tripower Building & Construction 17 08-13-2013 06:21 PM
Do I need to remove Styrofoam from the french drain? RickDel Building & Construction 23 09-07-2011 12:00 PM
Boat Dock and encapsulated float bekind42 Building & Construction 4 08-07-2009 11:59 AM
Red Styrofoam pad with stryro foam balls underlayment genner Flooring 4 03-31-2009 10:25 PM
Styrofoam vs. Plastic vent channels dpreznik Roofing/Siding 14 05-10-2007 02:58 PM
