Emp - Building & Construction - DIY Chatroom Home Improvement Forum
Old 06-12-2012, 06:59 PM   #1
emp
hi all !
here is a tech question would 6 inch of reenforced concret stop most emp from frying my radios and cbs sets ?
emp = electromagnetic pulse aka sun flare or nuke bomb
Can any 1 here tell me for sure ? or do i need a metal bax to ?
trooperfrank is offline   Reply With Quote
Old 06-12-2012, 07:24 PM   #2
the Musigician
DangerMouse's Avatar
emp = electromagnetic pulse.
and no, I do not believe concrete will help.
DM
Old 06-13-2012, 03:10 PM   #3
Post
EMP Expert to Assist
Originally Posted by trooperfrank View Post
hi all !
No. 6" of concrete will not suffice. I actually design EMP shielding so I understand it inside and out. The best thing to do is to build a Faraday Cage based upon TEMPEST or EMSEC standards. People often say that a metal box will work and that is true. But that metal box was not designed for protecting your electronics from an EMP and it may not cover the full EMP frequency spectrum. One little opening can cause the box to not be effective.
If you decide to build a box please make sure that you nest the equipment for added protection. Do not use a ground wire as most people suggest because it is not necessary and could work against you. Not grounding the box will cause the energy to be diverted around your box into the air instead of into the ground which during an EMP event will be electrically charged.
If you need help let me know
miket2012 is offline   Reply With Quote
Old 06-13-2012, 05:35 PM   #4
Use vacuum tubes instead.
And IIRC 10 megatons will cause brush fires within a 35 mile radius.
Old 06-13-2012, 08:26 PM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
Put enough rebar in it and ground the hell out of it....and it might reduce the induced current.....
The amount of current in an EM pulse is a function of the source, the distance from it, the length of the wire and the orientation of the target.
A wire perpendicular to the pulse will have little current induced.....whereas, a wire parallel to the pulse will get the maximum current induced....typically the current is expressed as amps/meter.
You will know if WWIII is starting if a 40 megaton blast happens in low earth orbit above the central US.
