Elevated Playhouse For Kids: Posts And Footings - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-19-2012, 07:39 AM   #1
Rewards Points: 117
Elevated playhouse for kids: posts and footings
Hi folks,
I'm going to be doing my first elevated playhouse in the backyard. 8x10' with the floor about 5 1/2 ft above ground.
I'm curious for peoples' experience with the posts and joists. I considered just making this a deck with framed walls added.
Would concrete piers, sunk to ground level, with the 4x4 posts in the pre-cast (4x4) slot on the pier's top be sufficient?
Also, joist size?
I will also be extending support off one of the ends to accommodate a beam for swings.
The "house" is just framed walls, window openings only, and a shingled roof (in Texas).
I know there are many ways to secure deck joists (scabs, slots, metal flanges) so I'll leave that for now.
Thanks in advance as always.
Dornier is offline   Reply With Quote
Old 11-19-2012, 07:46 AM   #2
DIY staff
Rewards Points: 7,174
Those pier blocks won't secure the thing properly----they sink into the ground and do not have attachments--so the swing or even a heavy wind will cause the structure to rock.
I suggest you dig four post holes and embed steel fasteners into the concrete piers--
You are really just building a small elevated deck with a light structure on top-----check out the deck fastener section for ideas about post anchors----
2x6 floor joists will do----
Old 11-19-2012, 08:14 AM   #3
Rewards Points: 117
Thanks for the quick reply. I'll head over there.
Old 11-19-2012, 08:16 AM   #4
Rewards Points: 117
Where is that section? Having trouble with the app's navigation.
Old 11-19-2012, 08:30 AM   #5
DIY staff
Sorry floor the confusion---I meant to head to the STORE and look in the decking section----
Stimson is the maker Strong Tie is one of their products---
A person with deck experience will come along soon----although I've built a few---I'm more of an interior pro---Mike----
Old 11-19-2012, 08:37 AM   #6
Rewards Points: 117
Got it.
Old 11-19-2012, 11:00 AM   #7
Rewards Points: 3,130
Do you know you'll likely need a set of drawings and a permit for this?
Old 11-19-2012, 11:11 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Well...this is what I did for my kids.....except for the posts, it's all redwood....
Posts are pressure treated 4x4's....set 2' into the ground with concrete.
The Following User Says Thank You to ddawg16 For This Useful Post:
oh'mike (11-19-2012)
Old 11-19-2012, 11:55 AM   #9
Architect
Rewards Points: 150
FYI, wood set below grade is a code violation although that is how things were all done in the not so distant past.
The current code requires that the wood posts are anchored to the top of the concrete pier which must be 4" higher than grade.
jcarlilesiu is offline   Reply With Quote
The Following User Says Thank You to jcarlilesiu For This Useful Post:
Old 11-19-2012, 12:00 PM   #10
DIY staff
The new treated wood rots when buried===the earlier version was better--
Old 11-19-2012, 12:35 PM   #11
Rewards Points: 117
I dot know about local codes except my HOA only requires application if it isn't attached to my house or garage and exceeds certain dimensions.
Will it resist rocking/swaying with the 4x4's anchored on top of piers like that?
Old 11-19-2012, 12:39 PM   #12
DIY staff
If your piers are poured into post holes 2 feet deep or more---yep--nice and firm----for a temporary structure like yours---even burring the posts like Ddawg did would be fine---the kids will be grown and gone before the posts go bad---
PT beams warp or twist off posts? windowguy Building & Construction 5 09-06-2012 07:24 AM
New posts and beams in crawlspace, post out of line WillK Building & Construction 1 02-26-2012 09:56 AM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 02:40 PM
Footings for 16" sq concrete support posts Leeside Building & Construction 1 01-25-2010 02:13 PM
Deck Posts replacement with load bearing columns from Pacific Columns, Inc Bruce Wilson Building & Construction 7 05-24-2009 02:55 PM
