Elevated Deck - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-11-2012, 12:22 PM   #1
Elevated Deck
I have seen several similar threads, so I think I know the answer to this, but is it POSSIBLE to build a 14'x14' deck elevated to 8' using only 4 corner posts (4x6 or 6x6)? Does it make a difference whether or not it is physically attached to the house? Thanks.
cheaps is offline   Reply With Quote
Old 05-11-2012, 01:04 PM   #2
Custom User Title
Rewards Points: 252
You will be limited by your beam.
no1hustler is offline   Reply With Quote
Old 05-11-2012, 01:16 PM   #3
Civil Engineer
Rewards Points: 4,520
It is possible to build such a deck in compliance with the International Residential Code (IRC) 2006 edition, which is the code my town works under. Your town may work under different codes, check with your building inspector. You need to size all your framing appropriately for the span, the tables in the code will tell you how large the framing members need to be.
The Following User Says Thank You to Daniel Holzman For This Useful Post:
cheaps (05-11-2012)
Old 05-11-2012, 04:56 PM   #4
Thanks for the response..are you referring to my cross/support beams or the uprights?
Old 05-11-2012, 05:29 PM   #5
Thank you for the help, I will check into that.
Old 05-11-2012, 05:33 PM   #6
robertcdf's Avatar
Anything can be done... as long as you've got the money to throw at it. What you're asking for is fairly easy though, however not typical to most deck construction. Steel frames can do those spans easily (like trex elevations)
robertcdf is offline   Reply With Quote
Old 05-11-2012, 05:52 PM   #7
Yeah, I figured I'd be putting a few extra dollars into the support system..but that's ok if I can get the results I am after. Thank you for the help, sir.
Deck Staining Nightmare steven994 Painting 6 04-06-2014 10:10 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Elevated Deck and Real Brick Wall stubits Carpentry 1 06-05-2009 07:14 AM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 12:17 PM
