Electrical Wires Touching Heating/air Cond. Tubes Between Joists - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-23-2007, 10:19 PM   #1
yummy mummy's Avatar
Rewards Points: 1,016
Electrical wires touching heating/air cond. tubes between joists
When the wires in my basement touch the heating and air conditioning tubes that run in between the joists, the contractor has put insullation to separate them, so that they don't come in contact with the vent.
Do I leave it like that when I put the drywall up in the ceiling?
Or do I have to do something?
thanks
yummy mummy is offline   Reply With Quote
Old 09-24-2007, 06:41 PM   #2
Eibwen
Are you speaking of the electrical wires touching the heating/cooling ductwork that the air flows thru?
Sammy is offline   Reply With Quote
Old 09-24-2007, 08:40 PM   #3
Yes Sammy.
It looks like pieces were put there by the contractor so that the wires don't touch the vents where the heat or air cond. flows through.
I was just wondering if I just leave them the way they are and just drywall as usual or if I need to do something else.
Thanks for you response.
Old 09-26-2007, 06:47 PM   #4
Eibwen
I would imagine they were put there to reduce vibrating on the duct work and causing a noise when the fan is on.
I would leave them in place.
Old 09-27-2007, 03:27 PM   #5
Home Improvement Guy
ron schenker's Avatar
The insulation is there to protect the wire from heat and vibration which could eventually wear off the wire's sheathing and electrify the duct work. Sounds hard to believe but I guess it's possible. It's cheap insurance and peace of mind.
ron schenker is offline   Reply With Quote
Old 09-27-2007, 04:59 PM   #6
Thanks Ron.
I will leave it there.
I think it was a code thing that the contractor had to do.
Electrical Wires and Shower Stall Burat Electrical 10 05-03-2007 08:49 AM
