Electrical Conduit Leaking Water Right Next To Foundation - Building & Construction - DIY Chatroom Home Improvement Forum
Old 04-11-2013, 03:54 PM   #1
w4y
Electrical Conduit leaking water right next to foundation
Hi,
I have a couple of PVC conduits that go to the cable/telephone/power for phone and cable cords. These conduits are just a couple inches from the foundation and they are leaking water, usually during rains and a few days afterwards. The house is on a hill, and I suspect the PVC conduits are filling with water through cracks and poorly sealed connectors, and running downhill towards the house.
I'm worried about the ill effects it might have on the foundation. At it's peak, the two conduits are leaking around 1 gallon of water/hour. Is this something to be concerned about? How should I go about fixing it?
w4y is offline   Reply With Quote
Old 04-11-2013, 04:36 PM   #2
Rewards Points: 744
I would sure be worried about 1 gallon of water per hour entering my house. Can you take a picture of both sides and post it here?
Seattle2k is offline   Reply With Quote
Old 04-11-2013, 04:38 PM   #3
w4y
The conduit doesn't enter the home. It's completely outside. The leak is happening right outside.
Old 04-11-2013, 04:44 PM   #4
Rewards Points: 744
Still, if you want advise, you should post a picture.
Old 04-11-2013, 04:48 PM   #5
w4y
Okay, I will try to post a picture tomorrow. Thanks.
Old 04-11-2013, 04:51 PM   #6
Rewards Points: 258
your worried about water leaking against the out side of your foundation? I would be worried about the water damage to the cables inside the conduit.
redman88 is offline   Reply With Quote
back flushing a water line. woodywoodwick Plumbing 5 10-18-2012 04:10 PM
Stone Foundation Leaking -Fixing myself ?'s Pitbull1783 Concrete, Stone & Masonry 9 08-10-2012 08:45 PM
Water Heater leaking at the nipples camerondon Plumbing 9 07-26-2012 07:56 PM
Water coming in at base of foundation Ptron Building & Construction 22 08-09-2010 09:51 PM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 08:09 AM
