Electric And Plumbing Codes - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-12-2008, 03:39 PM   #1
Electric and Plumbing Codes
Hi, we are in the process of looking for an electrician and a plumber to do some work in a basement that we're renovating. Our township follows standard UCC codes. I've had a bit of trouble/mixed messages from people I've talked to as far as what's permissable. Does the plumbing need to be done by a master plumber, or can it be done by someone else and then cleared by a master plumber? (And if it can be done by someone else, do they have to be licensed/insured?). Same question for the electric. (ie does it have to be done by a licesed professional, approved by one, or neither). Thanks for your help
ClnlBrahm is offline   Reply With Quote
Old 09-12-2008, 03:41 PM   #2
Oh, and I should probably add- as far as plumbing, we're not doing any demo. Everything will run on upflush and gray water pumps.
Old 09-12-2008, 05:14 PM   #3
Registered User
Termite's Avatar
Whether they're on the old uniform codes or the new international codes, this question can only be answered by the local jurisdiction. I can tell you with 100% certainty that this varies from city to city, even when they're under the same code. Call your local building department and ask them, just to be sure.
Old 09-12-2008, 05:17 PM   #4
Electrical Contractor
kbsparky's Avatar
I would not hire anyone who was uninsured. You are opening yourself to way too much trouble/liability with that one.
Old 09-12-2008, 05:28 PM   #5
Registered User
Termite's Avatar
Uhh, absolutely. Hiring an uninsured contractor is just asking for trouble.
Old 09-16-2008, 12:45 AM   #6
Thanks. Never intended on hiring anyone for any of the jobs who wasn't licensed and insured, just trying to clear a few conflicting opinions on this end as far as what is required. I appreciate everyone's help. Just found out we aren't required to have a master per the township, so we're in the process of hiring insured professionals. Thanks again
New Non Electric Home...Need Advice Forest Breath Building & Construction 18 09-08-2008 09:07 PM
Questions about electric water tank Piedmont Electrical 4 08-15-2008 02:51 PM
Hunting camp plumbing culver creek hunt club Plumbing 3 08-06-2008 09:21 AM
Should old plumbing be replaced? 3nr Plumbing 4 06-01-2008 09:40 PM
