EIFS Wall System - Building & Construction - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 11:06 AM   #1
EIFS Wall System
Is it feasible to install exterior insulation board directly to a sheet
metal substrate and utilizing a drainage system. Are there any other instances of this application?
Thanks, David
Dave Scarlett is offline   Reply With Quote
Old 02-18-2009, 11:08 AM   #2
Registered User
Termite's Avatar
What do you mean by sheet metal substrate? Are you asking if the sheet metal (siding?) can serve as a drainage plane behind the EIFS?
Old 02-18-2009, 11:44 AM   #3
Perhaps I should provide more information. I would like to cover an existing curtain wall system and I do not think that the existing curtain wall system
would support the normal 1/2" cement board sheathing. My thought was to eliminate the sheathing and install ?guage sheet metal mechanically fastened to
horizontal 7/8" hat channels @ 24" o.c. vertically. Install vapor barrier(drainage plane), insulation board with reinforcing mesh and finish coat. My original
question is could I subsitute the 1/2" sheathing with non corrigated sheet metal mechanically fastened.
Old 02-18-2009, 11:45 AM   #4
Rewards Points: 1,232
Exterior Insulation and Finish Systems are not a DIY'er product. They require a certified installer, and even then are iffy at best.
Advice is free, Lessons begin at 75 bucks an hour.
Tscarborough is offline   Reply With Quote
Old 02-18-2009, 12:46 PM   #5
Registered User
Termite's Avatar
Curtain wall, on a residence???
Old 02-18-2009, 12:48 PM   #6
Registered User
Termite's Avatar
I seriously doubt you'd get an EIFS manufacturer to warranty that application. You need to contact a representative of the company whose product you intend to use (dryvit, etc) to get their reccomendations.
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 08:45 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
~HELP~ Basement Wall is bowing earthad1 Building & Construction 6 06-05-2008 12:24 PM
Advantech Zip Wall Sheathing system RINAIL Building & Construction 1 05-04-2008 11:14 PM
Low Retaining Wall cibula11 Landscaping & Lawn Care 3 07-29-2007 12:02 AM
