Old 02-23-2011, 12:15 PM   #1
Egress windows
What is the min. egress opening requirement for Quincy, MA
24" x 24"?
cfournier3 is offline   Reply With Quote
Old 02-23-2011, 12:54 PM   #2
011010100110111101100101
Egress windows
24" x 24"?
5 square feet.
-- Joe
anesthes is offline   Reply With Quote
Old 02-23-2011, 12:59 PM   #3
concretemasonry's Avatar
Egress windows
Make sure you buy a window that is certified as an "egress window". The size is for the open space with the casement(if it is that style) fully opened. Cheating by removing the casement with any tools is not allowed when there is a fire. Just because it seems to have a nice large opening is not enough, because it must be installed low enough for children egress and large enough for a fire-fighter with gear (including tanks) to fight the fire from the inside.
The height of the bottom of the opening (not always sill or rough opening) above the finished floor will probably be 42" or 44", depending on your locality, so call and check that.
Make sure the window is certified and installed at the proper height and you should be OK
concretemasonry is offline   Reply With Quote
Old 02-23-2011, 01:32 PM   #4
old guy contractor
tcleve4911's Avatar
Egress windows
From my Harvey Catalog
"Typical egress requirements include 20" width and 24" height clear opening minimum dimensions AND 5.7 square feet of total minimum clear opening"
"clear opening" is the key phrase here
tcleve4911 is offline   Reply With Quote
Any restitution for VERY late windows? msbriggs Building & Construction 21 10-05-2010 07:25 AM
Installling Basement Egress Windows JohnnyB Building & Construction 2 04-11-2010 08:15 PM
Windows XP Mode in Windows 7! poppameth PC Repairs & Upgrades 5 04-28-2009 01:18 PM
Windows: RO sill height and egress question. iMisspell Building & Construction 3 10-25-2008 01:55 PM
