Egress Window Well Design? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-29-2010, 02:23 PM   #1
Rewards Points: 562
egress window well design?
Has anyone constructed there own window well enclosure for a below grade egress window? Construction methods and materials used? How about a clear covering to keep debris and weather out?? ALL ideas or pics appreciated. -thanks -d-
4just1don is offline   Reply With Quote
Old 11-30-2010, 09:51 AM   #2
Rewards Points: 562
no ideas
No opinions?Awfully quiet here??
Old 11-30-2010, 11:23 AM   #3
A Little Of Everything
Rewards Points: 1,364
I installed a couple egress windows & wells in one of our houses. I had intended to build my own "well", but kind of ran out of time with winter coming, and simply installed one from Home Depot.
There are some things you'll want to be sure to do - like dig down a foot or more lower than the bottom of the well, then fill the area with pea gravel, for drainage. Your city might also have some specific code regulations.
Sorry I couldn't be more helpful.
DrHicks is offline   Reply With Quote
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 01:23 AM
egress window kikipauw Building & Construction 3 11-10-2010 07:30 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
