Egress Window Wall - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-09-2010, 06:56 PM   #1
egress window wall
I'm putting in 2 egress windows in my basement and want to build a small wall around it (3 X 2 feet). About 25% of the window is above ground, in the end I'll have to dig about 30 inches. My window cranks open outside. The window wells that I see in stores are a little expensive. I was searching in the internet and found this link - http://www.egresswindowguy.com/timber1.html. One of the picture shows landscape timber being used for the well walls. This would work excellent for me as I'm thinking it would end up cheaper for me. I have some questions - I'd appreciate answers for any of them.
1. Why is landscape timber cheaper ($3.97) compared to almost similar sized treated lumber ($25). I think both of them are treated isn't it?
2. What are the precautions and preparations I need to do so that the landscape timber doesn't rot in 2/3 years?
3. I'm planning to prime & paint the landscape timber before using it to build the mini wall. Would a normal wood paint/primer work?
Thank You for the time.
Joel
saturn78 is offline   Reply With Quote
Old 05-10-2010, 05:16 AM   #2
DIY staff
Rewards Points: 7,174
Landscape timbers are cut from very small trees.--PULPWOOD--That's why they are cheap.
The wood is very fast to rot--No way to stop it. Big mistake to use them for holding back the earth in your window wells.
Use the steel corrugated window wells--You don't want to add another high maintenance item to your home.
---Mike---
Old 05-10-2010, 05:27 AM   #3
Use used rail road ties. not the prettiest looking, but no worries about rot for years.........
mark942 is offline   Reply With Quote
The Following User Says Thank You to mark942 For This Useful Post:
oh'mike (05-10-2010)
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 4 04-04-2017 07:38 PM
"Defogging" double-pane windows .... a gimmick?? alexz General DIY Discussions 133 03-10-2010 12:35 PM
New Window in a Load Bearing Wall pleuraxeraphim Building & Construction 5 04-15-2009 07:08 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
