Egress Window Help - Building & Construction - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 07:43 PM   #1
egress window help
Im trying how to decide on how to finish off the area around the outside of my egress window. Im thinking either use treated 2x6 and tap-con to the foundation so it matches the rest of the window well or I can just paint it. Any suggestions? I dont know if it's bad to put a lot of tap-cons into the cinder block foundation. the window was installed before I bought the house or I would have had the contractor finish it. here is a picture.
oba97 is offline   Reply With Quote
Old 05-27-2012, 08:23 PM   #2
Rewards Points: 636
looks to me like it has wood around it already so paint with exterior paint or nail trim over it
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 05-27-2012, 08:28 PM   #3
kwikfishron's Avatar
Rewards Points: 370
How about a guardrail and gate. It would certainly change the view from the topside. That's a deep hole, you should have something there.
kwikfishron is offline   Reply With Quote
Old 05-27-2012, 08:36 PM   #4
Rewards Points: 13,450
Vinyl brick moulding.
Old 05-27-2012, 08:52 PM   #5
ya, I plan on putting up a guard rail. I am looking specifically to cover the exposed cinder block. should I just paint the block or cover with wood?
Old 05-27-2012, 09:00 PM   #6
Rewards Points: 370
Just continue the siding on down.
Egress Window Recommendations jhakkim Building & Construction 4 03-08-2012 09:05 AM
Egress Window Header? ottoguy Building & Construction 3 09-08-2011 10:22 PM
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 12:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
