Egress Window With Header Required - Building & Construction - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-15-2009, 08:05 PM   #16
thanks for pointing out the h-1. i was looking at some in the store today and was not positive that i needed them but now i will definetly use them.
nwmod39 is offline   Reply With Quote
Old 08-19-2009, 08:20 PM   #17
before and after pics....
also the laundry room where window #2 will be installed. had to move the sink, counter and shelf out of the way to get ready for the concrete to be cut friday.
egress window with header required-basement-001.jpg   egress window with header required-c3-035.jpg   egress window with header required-c3-006.jpg
Old 08-20-2009, 03:27 PM   #18
Registered User
Rewards Points: 5,254
Vinyl windows require continuous shim support under them, it's on the installation instructions. Hey, looking good, the window, not the plumber's crack in the middle picture. This is a family friendly site......
Be safe, G
Gary in WA is online now   Reply With Quote
Old 08-20-2009, 07:44 PM   #19
thanks again bro. there will be 100% shim support under the window when i finish.
Old 08-25-2009, 07:28 PM   #20
2nd window is installed. went tons faster than the first since now i know what to do and what not to do.
i will be doing the well in blocks. i do not like the looks of the metal well tubs.
thanks for all the helper along the way. i gaurantee i will have tons more questions as we get farther along in finishing the basement.
thanks
steve
Old 11-22-2011, 10:38 PM   #21
Similar Header Question!!
Hi,
I'm about to tackle the same project, except I am doing it with a basement window size 48"w x 55"h, so am planning a R.O. width of 51". My house was built in 1900 in MN. I'm trying to determine the type of header I need. The rim joist construction is completely different than the house pictured.
Instead of a flat 2 by sill plate with joists and rim joist sitting on top of it, my framing on top of the 12" wide poured concrete wall is what appears to be a 6" wide x 8" tall beam instead of a sill plate and rim joist, and, the floor joists are notched into this beam about 3-4" inches of the beam cut out it looks like for each floor joist. I hope this makes sense.
I want to play it safe with the window header- this is almost directly in the middle of the 50' long 2.5 story duplex wall that the gable roof is supported by. I was thinking about using either 3or4 stapled 2x8s or 2x10s as a header for this window.
I should mention that currently there is a 34" inch wide glass block window where I will be cutting around. The glass block window has no header whatsoever, just a 1x4 barely stapled (i can almost pull out the 1x4 with fingernails) to the sill beam (don't know the proper term for this Sill plate Beam). Over the 51" wide span I'm planning to remove, there are 4 floor joists (16" on center) which are 2x8 in size. (I guess in the old days instead of joist hangers they notched joists into girders/support beams??)
Lastly, when measuring how close to the floor I am getting when planning for the 56.5" window height+sill-plate 2-by, if I add an extra 9.25" for 2x10 header, this will leave me still up about 20" from the basement floor. Is this too close to the floor? I am going to be digging well below the frostline 42" in the outside soil. It is going to be a hell of a dig through the limestone soil mix outside! (when I dug out other egress wndws, it was common to find 2'x1'x2' limestone random blocks in the soil, a good 60lb rock!).
One last question I thought of, do the headers need to be treated wood or regular? Perhaps just the exterior 2 by on the header? Any ideas to Trim out the exterior header ? maybe a big piece of flat PVC moulding?
Any ideas for the correct header support? Thanks!! Adam
AdamH is offline   Reply With Quote
Old 11-22-2011, 10:58 PM   #22
Residential Designer
AndyGump's Avatar
Rewards Points: 664
Send a message via Skype™ to AndyGump
Hi Adam, and welcome to the site.
Could you start this as a new thread please.
I think you will get more responses that way.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Gary in WA (11-23-2011)
Old 11-22-2011, 11:03 PM   #23
Andy-
good idea, and I just started the new post at:
Need to determine proper Basement Window Header size-
thanks-
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 01:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
