Egress Window Header? - Building & Construction - DIY Chatroom Home Improvement Forum
Old 09-07-2011, 05:17 PM   #1
I am going to replace an existing window with an egress casement window. The current window has no header which I think is odd. I'm trying to decide if I should replace the window with one of the same width and not put in a header, or replace it with a wider window and put in a header. If I need a header how big?
The window will be between 2' 6" wide and 3' wide. So it will have to support 2-3 headers. The house has 2 stories above this and the span of the floor joist is 16 feet with a 2x12. Attached is a picture of the current window.
ottoguy is offline   Reply With Quote
Old 09-07-2011, 05:30 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Someone here will have a good answer but I'm wondering why if the sill plate has been suitable (all this time) for the existing window why wouldn't it be suitable for a new egress unit?
Don't know that I have ever seen any kind of a "header" over that type of basement window. Mine doesn't have headers either.
XXX
Old 09-07-2011, 05:46 PM   #3
Buying the first round
LIHR's Avatar
I would install a 2x header the same size as the floor joists ( on top of the sill plate) and go ahead with the larger window.
http://www.ranteso.com/
LIHR is offline   Reply With Quote
Old 09-08-2011, 10:22 PM   #4
Registered User
Rewards Points: 526
What is the blocking in the joist bay over the right window side?
Does it run across the window with the joists on metal hangers?
Gary
egress window with header required nwmod39 Building & Construction 22 11-22-2011 10:03 PM
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 12:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 10:00 PM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 04:15 PM
