Egress Window With Brick Veneer - Building & Construction - DIY Chatroom Home Improvement Forum
Old 11-17-2011, 02:01 PM   #1
Egress window with brick veneer
Can someone point me in the right direction on this. I am installing an egress window in the basement and using 2x6's for a header. Should I have the concrete cutter start the cut right below the brick (if so, do I need to use a lintel to support the brick), or, should I leave some concrete below the brick.
My other question is what is usually done on the exterior of a house to cover up the treated lumber header? I've attached images of the outside and inside of the wall in question.
Thanks for any help in advance.
Egress window with brick veneer-img_4350.jpg   Egress window with brick veneer-img_4356.jpg
munsonr1 is offline   Reply With Quote
Old 11-17-2011, 02:58 PM   #2
Rewards Points: 5,336
The size and position of the window might dictate where you cut. If possible, I'd leave the concrete in place to use as the lintel. Otherwise you would need to install some steel under the brick.
I'd trim the exterior with one of the composite alternatives.
Ron
B. Franklin 1759
Tags
brick , egress , veneer , window
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 08:11 PM
Installing a Replacement Vinyl window with brick mold jlatulippe Carpentry 4 06-23-2011 02:05 PM
Insulaion over brick veneer ? Any suggestions? 4wings Building & Construction 4 01-08-2010 04:58 PM
New Air Conditioner and Brick Veneer RayB1 Building & Construction 2 11-30-2009 08:54 PM
Brick veneer pulling from front of house, how to re-anchor? tidal9 Building & Construction 5 06-13-2008 08:08 PM
