Old 09-20-2010, 04:21 PM   #1
egress window
I want to install an egress window in the corner of my basement to make a legal bedroom, it's a cement basement (underground), how far down from floor joist should i cut the hole and how far from the corner?
oilman is offline   Reply With Quote
Old 09-20-2010, 06:05 PM   #2
egress window
You should get knowledgeable onsite guidance before picking up any tool. There are poured concrete foundations and concrete block foundations. There are no cement foundations.
Ron
Old 09-20-2010, 06:20 PM   #3
concretemasonry's Avatar
egress window
When it comes to the opening, you pick out a approved egress window and cut the rough opening to make sure the bootom of the open window is a low as the required height and not any higher. This maximum height limit is set to allow children to get out. I have heard of people having to get a code approval (whether required by law of just common sense for resale) before the carpeting was installed.
You should also make sure your exterior well is sized to permit a firefighter down and get ino the interior with gear on.
The lintel size and type will be determined by the material above the rough opening and the load on the wall, even if not a loadberaing wall, it does cary the dead loads of the walls above. An engineer should be used for the lintel design.
Usually it is better to use concrete sawing contractor since they can come in and cut and remove the debris in an hour or two since they have the equipment and knowledge.
Dick
concretemasonry is offline   Reply With Quote
Bedroom window egress codes drtbk4ever Remodeling 21 02-27-2013 03:21 PM
Egress window dimensions ClnlBrahm Building & Construction 28 12-22-2010 01:23 AM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 06:11 PM
Keeping Egress Window Code Compliant ClnlBrahm Building & Construction 2 09-11-2008 11:00 PM
DIY Egress window in basement? ClnlBrahm Building & Construction 5 09-03-2008 12:15 PM
